Reply 3240 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-20, 18:04:
Testing: Grand Prix Legends
CTD right after logo
That should work. You'll have to run it at "default" resolution with fill screen aspect ratio.
There's a trick to installing the game. I think you nee the GPLS installer to get it to work and you need t install it without any of the update models (i.e. use stock cars only).
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3241 of 3589, by sharangad
The game won't start up with opengl anymore. You'll have to manually configure rredline. There's a dll name to change in the config. I'll post it in a bit.
[EDIT]\
App.ini
[ Graphics ]
lastRasterizerDLL = renddll.dll ; Last rasterizer DLL selected
That's what you need. You'll have to run the game through the RLauncher OR copy the two RRedline dlls in there directly.
You'll also need fill screen (default for 4:3) aspect ratio and use the default resolution. Higher resolutions can be selected from within the game.
Reply 3242 of 3589, by sharangad
The nirvtek.com site has been hacked again. The hosting provider has recommended a clean start. The hack appears to have originated from an older wordpress site, not the current one. The hacker or hackers appears to have been sending out explicit spam using the admin email and some of the scripts they used to login can't be deleted, they appear to recreate themselves. So the site will be down and moved to a fresh server over the next few days.
Anyhow, Merry Christmas and a Happy New Year to all!
[EDIT] Server has been rebuilt.
Reply 3245 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-22, 17:24:
GPL : can't make it work on my system, crashes with Integer Division by Zero error.
Did you install it with the gpls installer and switch it to rredline?
Reply 3247 of 3589, by sharangad
Descent II working a little bit better in dosbox-rendition. It's still glacially slow though.
- Menus render properly
- Cutscenes should render a bit better
- Textures (distant mips) still missing
https://nirvtek.com/downloads/RReady.Alpha.20251223.001.7z
MD5: 299e1a87ce351b17bc52914da02e5082
Reply 3249 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-23, 19:22:
crash logs of GPL
Edit: Zandvoort has blue squares flickering on flags of country instead should be flag textures only , so its a rare little glitch, happens on distance, maybe mipmap failure.
I'll check it out, thanks!
Reply 3250 of 3589, by sharangad
crash logs of GPL
Can't actually see anything wrong with the logs. I think V1.0.0 of the game just won't run on modern Windows. I also didn't see blue squares flickering in the flags.
I've captured some footage of Zandvoort on RReady and V2100; I'll post them in a bit.
Reply 3251 of 3589, by sharangad
Zandervoort - RReady https://youtu.be/a5QxOOSpweo
V2100 - https://youtu.be/eJ-iJw5OKbk
The mirrors appear to be broken, but I'm going to fix that. Didn't notice the flags glitching.
Reply 3253 of 3589, by RaVeN-05
Understand.
Some findings which is low chance to be RRedline API game:
FIFA 99 - have veritea.dll, dll itself references to redline.dll and verite.dll , probably could be activated by renaming veritea.dll to d3da.dll and running game with -D3D command line, but game CTD instantly with wrapper.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3254 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-25, 16:44:
Understand.
I think I have the game. I'll try it on real hardware.
Reply 3257 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-25, 17:24:
Same situation with Future Cop L.A.P.D.
setup\3ddata.dat
Future cop's 3d setup seems to imply that /G: D3d and /M: d3d should be used for Rendition. I'll test it on the hardware tomorrow.
Reply 3259 of 3589, by sharangad
RaVeN-05 wrote on 2025-12-25, 21:18:
Interstate '76: Nitro Pack have redline renderer zredline.dll, but can't activate it, will try on original hardware, i have access
It does work, it needs the -rredline switch (same as i76l, I think.
On windows you need the dgvoodoo D3D dlls and dxwnd. The help file for rready (click help) has a download link for a pre-configured build (other than the exes path).
