RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3240 of 3244, by sharangad
RaVeN-05 wrote on 2025-12-20, 18:04:
Testing: Grand Prix Legends
CTD right after logo
That should work. You'll have to run it at "default" resolution with fill screen aspect ratio.
There's a trick to installing the game. I think you nee the GPLS installer to get it to work and you need t install it without any of the update models (i.e. use stock cars only).
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3241 of 3244, by sharangad
The game won't start up with opengl anymore. You'll have to manually configure rredline. There's a dll name to change in the config. I'll post it in a bit.
[EDIT]\
App.ini
[ Graphics ]
lastRasterizerDLL = renddll.dll ; Last rasterizer DLL selected
That's what you need. You'll have to run the game through the RLauncher OR copy the two RRedline dlls in there directly.
You'll also need fill screen (default for 4:3) aspect ratio and use the default resolution. Higher resolutions can be selected from within the game.
Reply 3242 of 3244, by sharangad
The nirvtek.com site has been hacked again. The hosting provider has recommended a clean start. The hack appears to have originated from an older wordpress site, not the current one. The hacker or hackers appears to have been sending out explicit spam using the admin email and some of the scripts they used to login can't be deleted, they appear to recreate themselves. So the site will be down and moved to a fresh server over the next few days.
Anyhow, Merry Christmas and a Happy New Year to all!
[EDIT] Server has been rebuilt.
