RReady (Rendition Verite & CGL wrapper) Test Build (Alpha 1)
Reply 3401 of 3411, by sharangad
Hot linked drivers produce things like this now:
026/5/18|17:26:17.180 !!! CGL SendStream
2026/5/18|17:26:17.180 !!! Ptr is 00264DA0, int param is 00000005
2026/5/18|17:26:17.180 ^^^^ Render Operation 0001 (CGL_TRIANGLE (0200)), num vertices 6, mask 0011 (Props Shader,Texture,)
2026/5/18|17:26:17.180 pVertex is 00252710
2026/5/18|17:26:17.180 (413.625000, 198.500000)
(410.375000, 197.062500)
(410.812500, 197.625000)
(408.062500, 195.000000)
and
026/5/18|17:26:17.180 ^^^^ Render Operation 0001 (CGL_QUAD (0300)), num vertices 8, mask 0011 (Props Shader,Texture,)
2026/5/18|17:26:17.180 (406.125000, 191.500000)
(406.000000, 192.375000)
(407.437500, 192.187500)
(407.687500, 191.250000)
(413.625000, 192.250000)
(421.687500, 191.000000)
(419.625000, 189.000000)
(414.687500, 189.750000)
and with that back to ICR2 tomorrow.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3402 of 3411, by sharangad
Battle Arena Toshinden (flat shaded polygons):
https://youtu.be/fd1cmn1u1Io
This can run at 60 fps BTW, even though it's not doing that here.
Update: Also running on core=simple, leftover from an ICR2 test.
Also on Patreon with a few more details:
https://www.patreon.com/posts/battle-arena-cg … ntent=join_link
Reply 3403 of 3411, by sharangad
Final Toshinden video of the week with texturing and blending working. Polygons are another matter:
https://youtu.be/I0IVEQpSuLQ
or at 1080p.
https://www.patreon.com/posts/cgl-update-1586 … ntent=join_link
Reply 3404 of 3411, by RaVeN-05
new discovering's:
EarthSiege 3: StarSiege Alpha Tech Release 2.1
have rbdgfx.dll which refers to redline and verite dlls with many exports, game seems can't use it or i can't find a way how to enable or force it. in game it called software renderer. i didn't started new game , just messed around in menu and options.
Need for Speed III
have veritea.dll and unfortunately it can't be used. game simply not runs.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3405 of 3411, by sharangad
RaVeN-05 wrote on 2026-05-21, 12:29:
new discovering's: EarthSiege 3: StarSiege Alpha Tech Release 2.1 have rbdgfx.dll which refers to redline and verite dlls with m […]
new discovering's:
Need for Speed III
That's great news. Maybe they can be hacked.
Reply 3406 of 3411, by sharangad
sharangad wrote on 2026-05-18, 11:20:
Thanks! Something's off here, could you try this instead:
https://nirvtek.com/downloads/3DBVLB32.20260518.004.7z
MD5: 110a853157bb25f822d154bff6645d56
@gonaeu, when you get a chance, I'd like logs from this, if possible. There's no rush.
Reply 3408 of 3411, by sharangad
Gona wrote on 2026-05-24, 19:00:
Sure, here it is.
Thanks @Gona, but I think you need to run run.bat. It's a low priority task.
RReady widescreen again:
https://youtu.be/rvMuXuJjC80
( or on my Patreon:https://www.patreon.com/posts/indycar-racing- … ntent=join_link)
I used two of Hacker's tricks to make this work. The game internally renders at 1600x1200 instead of 640x480 and matrix scaling gets used for widescreen. The problem is that at 32:9 there's a fair bit of fish-eye. At 21:9 it's fairly mild and at 16:9 pretty much non-existent.
Reply 3409 of 3411, by Gona
sharangad wrote on Today, 12:59:
Thanks @Gona, but I think you need to run run.bat. It's a low priority task. […]
I'have copied run.bat line to the autoexec.bat
Now I have ran it separate. Same size, some bite different.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 3410 of 3411, by sharangad
Gona wrote on Today, 16:58:
You're right! I seem to have lost track of what I was doing with this.
Thanks!
