new discovering's:
EarthSiege 3: StarSiege Alpha Tech Release 2.1
have rbdgfx.dll which refers to redline and verite dlls with many exports, game seems can't use it or i can't find a way how to enable or force it. in game it called software renderer. i didn't started new game , just messed around in menu and options.
Need for Speed III
have veritea.dll and unfortunately it can't be used. game simply not runs.
RaVeN-05wrote on 2026-05-21, 12:29:new discovering's:
have rbdgfx.dll which refers to redline and verite dlls with m […] Show full quote
new discovering's:
Need for Speed III
I used two of Hacker's tricks to make this work. The game internally renders at 1600x1200 instead of 640x480 and matrix scaling gets used for widescreen. The problem is that at 32:9 there's a fair bit of fish-eye. At 21:9 it's fairly mild and at 16:9 pretty much non-existent.
I'have copied run.bat line to the autoexec.bat
Now I have ran it separate. Same size, some bite different.
You're right! I seem to have lost track of what I was doing with this.
I haven't spend much time on Toshinden, but enough to get it a bit more functional: https://youtu.be/aXsFiMj9xxA
Aargh! My motherboard /cpu is dead. 3 long beeps+boot led comes on. It powers on automatically without the power led. Hitting the power switch flips the error led from boot to vga. All the fans spin.
I have to find a b450 mobo tomorrow or I'll be out of action until Tuesday, thanks to the Buddha's birthday being on Saturday. Most of the places here are out of stock or in pre-order states. That's assuming the cpu isn't toast. Currently running on a lowly core 2 duo. Visual studio can't even track the mouse or register keystrokes.
I may be forced to optimize this for slower machines now.
