Reply 3420 of 3460, by sharangad
- l33t
ICR2 widescreen 21:9 now working and 16:9 cockpit view has changed:
- The cockpit is working at 21:9, 32:9 and has been revised for 16:9.
- Dosbox-staging-Rendition should run with displaced sprites with the patched ICR2. This error will be fixed in another test build.
- The exterior of the car while driving won't change colour to match the current car. This will be fixed in a later build.
Dosbox-Rendition is the preferred version of dosbox, at least for the moment.
Test build:
https://nirvtek.com/downloads/RReady.Alpha.20260607.001.7z
MD5: 699e13175998d6c37397f4e9097cfe59
Patched build of ICR2:
https://nirvtek.com/downloads/ICR2.Widescreen … .20260605.01.7z
MD5: cb259749e20003e9adace6696ca2bdad
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
