Reply 3420 of 3467, by sharangad
ICR2 widescreen 21:9 now working and 16:9 cockpit view has changed:
https://youtu.be/2uN8J1d7cvw
- The cockpit is working at 21:9, 32:9 and has been revised for 16:9.
- Dosbox-staging-Rendition should run with displaced sprites with the patched ICR2. This error will be fixed in another test build.
- The exterior of the car while driving won't change colour to match the current car. This will be fixed in a later build.
Dosbox-Rendition is the preferred version of dosbox, at least for the moment.
Test build:
https://nirvtek.com/downloads/RReady.Alpha.20260607.001.7z
MD5: 699e13175998d6c37397f4e9097cfe59
Patched build of ICR2:
https://nirvtek.com/downloads/ICR2.Widescreen … .20260605.01.7z
MD5: cb259749e20003e9adace6696ca2bdad
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3421 of 3467, by BEEN_Nath_58
Does Team Apache still have startup lockup issues?
Reply 3422 of 3467, by sharangad
BEEN_Nath_58 wrote on 2026-06-07, 17:26:
No, I fixed that the way you suggested. I last tested it in March and the game started up OK.
Reply 3423 of 3467, by sharangad
I still haven't figured out why the menu screens don't update. The game uses front buffer rendering but for some reason, updates don't render something. It can sometimes be triggered by sending a spurious WM_TIMER command but even that's not entirely reliable. It's almost like the device context is locked, though I don't entirely know how that's done.
Reply 3424 of 3467, by BEEN_Nath_58
sharangad wrote on 2026-06-08, 04:57:
DxWnd had two techniques to refresh a not refreshing screen: 1. automatically force refresh on every primary surface blit, 2. something I don't understand but it required using the Time Stretching settings, and helped the game Die by the Sword which refresh on only mouse movement
Reply 3425 of 3467, by sharangad
BEEN_Nath_58 wrote on 2026-06-08, 06:12:
I'll try those in a bit. Bit busy with ICR2 widescreen:
Here's the state of play in 32:9:
https://youtu.be/LTtDS2SbNhU
OR
https://www.patreon.com/posts/indycar-racing- … ntent=join_link
https://nirvtek.com/downloads/RReady.Alpha.20260609.003.7z
MD5: 3be6297e068997a9cb1bdd806afaa01b
You will need this patched version of ICR2:
Reply 3426 of 3467, by sharangad
21st Century Digitial Boy now rendering correctly:
https://youtu.be/azHjzdkgvBs
(Also on my Patreon:https://www.patreon.com/posts/21st-century-bo … ntent=join_link)
21st Century Digital Boy now has 3D sections rendering badly:
https://youtu.be/ON-PtEXEWck
Toshinden now has working perspective correction:
https://youtu.be/o-kPyBEktB4
RReady Alpha (with ICR2 widescreen alpha and CGL support):
https://nirvtek.com/downloads/RReady.Alpha.20260612.001.7z
MD5: e9d4a5b3bf3105e279076aae366069ff
https://nirvtek.com/downloads/RReady.Alpha.20260610.001.7z
MD5: 3f454c39660fa1f2539ef124e834a518
CGL Drivers:
https://nirvtek.com/downloads/RReady.CGLDrive … 20260610.001.7z
MD5: bcd5b7a7104fbd71877b077b07527575
Update: More misadventures in 32:9 widescreen - https://youtu.be/ac4qwA6dv5Q
Reply 3427 of 3467, by sharangad
ICR2 mirror offsets. I'm hoping the player car offsets are also in there somewhere. It's Patreon only, youtube is losing my upload:
https://www.patreon.com/Rready/posts/icr2-wid … ntent=join_link
I'll try reuploading it later.
(Later after third upload :
https://youtu.be/ck2Pm8ZUtVw)
3D Blaster VLB more progress:
https://youtu.be/aAB5G5Bb_Zk
Reply 3428 of 3467, by sharangad
Camera offset for icr2:
https://youtu.be/9MISlUK3g1U
Also on Patreon: https://www.patreon.com/Rready/posts/indycar- … ntent=join_link
Free look during a race in ICR2:
https://youtu.be/g4CLKAVSP20
and at 1080p:
Reply 3429 of 3467, by sharangad
Here's my latest attempt at 32:9. The cockpit/HUD is messed up, but I *think* the aspect ratio is correct here:
https://youtu.be/ogi2mlfzGoI
A diff looks like this:
So a vertical displacement should be all that's needed.
Reply 3430 of 3467, by sharangad
Freelook in icr2 again with a slightly more demonstrative video:
https://youtube.com/shorts/hj7t1-lE1B4?feature=share
Here's the best bet at getting everything right by simply expanding the viewport to the left and right. It has a few issues, but if it works, would be fantastic:
https://youtu.be/IzTpsD1ZP3A
Reply 3432 of 3467, by sharangad
Spectator mode for replays (21:9):
https://youtu.be/qbcY3OvQz28
Once again the cam-car rotates with the camera. If I can fix this I think I can get the cockpit view working perfectly by applying a world offset to both the player car and the rest of the world. The rest of the word works ok, the player/POV car not so much:
This is the first test build with mouse freelook support. It can be disabled by adding the following line, if it doesn't already exist:
[Rendition]
freelook=false
to the dosbox-rendition.conf settings file (dosbox settings button in RLauncher).
RReady Alpha:
https://nirvtek.com/downloads/RReady.Alpha.20260623.003.7z
713018cc80137addfe82935999787bf0
https://nirvtek.com/downloads/RReady.Alpha.20260623.001.7z
MD5: 7b97564d4fc22479a4a31e5e823e46ea
It requires this new patched game binary:
https://nirvtek.com/downloads/ICR2.Wide2.20260619.001
MD5: 5138939b1dd618cef66305112fbb3b3a
The build also supports CGL for the 3D Blaster PCI for the following apps: Battle Arena Toshinden, 21st Century Digitial Boy, Actua Soccer and Euro 96. Virtua Soccer probably works as well. The 3 football games are probably rebadged versions of the same game.
This is a non-final test build for feedback only.
Actua soccer with working overlays and Euro '96:
https://youtu.be/XD8GwNpGuGs
Reply 3435 of 3467, by RaVeN-05
Tested
Sub Culture
Seems everything is correct
probably minor issues:
not perfect texture tiling (sometimes we can see lines)
alpha issues (on corals)
not perfect font (some lines and tiny corruptions)
https://www.twitch.tv/videos/2807649499
issues at:
8:30, 10:45, 53:35
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3436 of 3467, by sharangad
RaVeN-05 wrote on 2026-06-28, 21:40:
Tested Sub Culture Seems everything is correct probably minor issues: not perfect texture tiling (sometimes we can see lines) al […]
Tested
Sub Culture
issues at:
8:30, 10:45, 53:35
Thanks dude! Checking it out now.
Update: The texture tiling problem can be minimised, but not eliminated, by disabling texture coordinate rounding (to nearest integer pixel). But doing this breaks the font rendering with some lines of text in the mission screens losing their bottom row(s?) of pixels. I will fix these two. The issue with the coral, I'm not entirely sure how to fix. I'll try and reproduce it on original hardware as well to make sure this isn't a game bug.
Reply 3439 of 3467, by sharangad
I'll have to test "Sub Culture" during the weekend. Too much stuff going on.
Z-Buffering wasn't working in the "21st Century Digital Boy" demo. I was sending the wrong z-buffering command. i had to set the z-test mode to "less than" instead of "always":
https://youtube.com/shorts/TXxsRbPZtag?feature=share
(Also on my Patreon at 1080p:
https://www.patreon.com/Rready/posts/21st-cen … ntent=join_link)
Actua Soccer state of play (This and Euro '96 appear to be 256 colour games using sprites through the CGL API):
https://youtu.be/OSiUGKKS_Pk
and Euro '96:
https://youtu.be/QIprI7i9BKU
