First post, by ulinta
Hi Dege,
First of all, thank you for continuing to maintain dgVoodoo2.
I'd like to report a reproducible crash that only occurs when using dgVoodoo2 with the **Taiwan version of Cross Gate (cg.exe)**, an old 32-bit DirectDraw game.
### Environment
* Game: Cross Gate (Taiwan version, cg.exe)
* OS: Windows 11 24H2 (Build 26100)
* dgVoodoo: 2.87.3
* DDraw.dll version: 4.7.1.3000
### Problem
The game works normally, but after running for approximately **6-12 hours** (usually while the character is idle running a player shop), it crashes to desktop.
I don't remember this happening before I started using dgVoodoo2.
I first noticed the problem with 2.87.2 and it still occurs with 2.87.3.
I also tested with **Fast video memory access disabled**, but the crash still occurs.
### Event Viewer
Faulting module:
DDRAW.dll
Exception code:
0xC0000005
Fault offset:
0x0002FDDE
### WinDbg
I enabled Windows LocalDumps and analyzed the crash dump.
The crash always occurs at:
DDraw+0x2FDDE
Instruction:
mov edx, dword ptr [ecx+1B8h]
Register state:
ECX = 00000000
The instruction dereferences a NULL pointer, resulting in an access violation.
Call stack:
DDraw
DDraw
DDraw
cg.exe
DDraw
Unfortunately, there are no public symbols available, so WinDbg cannot resolve the internal function names.
### Additional Information
I have collected:
* Full crash dump (~1.45 GB)
* WER report
* Event Viewer logs
* WinDbg analysis
I'd be happy to upload the dump or test any debug build if it would help investigate the issue.
Thank you very much for your time.
Reply 1 of 5, by Dege
Thx for the report!
The crash point is an internal function called when a new DD surface is being created. The this pointer is NULL which is weird, the only thing that I can think of is that there is a resource leak and the 2GB address space is slowly eaten up by a lot of leaked DD(?) objects.
1) Could you check out the virtual size of the process when it crashes (e.g. in Process Explorer)?
2) Or check out if the virtual size is slowly growing as the game is being run?
3) And trying to run the game on a GPU from a different vendor? Because unfortunately I myself had cases when I got memory leaks from an Intel driver (integrated).
Reply 2 of 5, by ulinta
Hi Dege,
I collected the information you requested.
I monitored the first cg.exe process while leaving the game running as a merchant for many hours.
Results:
- The Virtual Size keeps growing steadily over time.
- It starts at about 550 MB and gradually increases to around 1.7 GB.
- Private Memory also keeps increasing during the same period.
This seems to support your suspicion of a possible memory/resource leak.
However, I also noticed something new.
Previously the game usually crashed with DDraw.dll (I uploaded the dump before), but during these recent tests the game often freezes instead of crashing.
When it freezes:
- The cg.exe process is still running.
- The game window remains on the last rendered frame.
- The game becomes completely unresponsive.
- I have to terminate the process manually.
- The freezes occurred while the game was simply running as a merchant with no user interaction and no active trading.
One interesting observation is that the Virtual Size continues increasing until roughly 1.7 GB, then stops growing. The process remains alive in this frozen state until I manually terminate it.
Unfortunately, I have not been able to test the game on a GPU from another vendor because I only have a system with Intel UHD Graphics 730.
I also collected the memory logs. Unfortunately, the forum does not allow me to upload CSV files. If you would like to examine them, I can upload them to a cloud storage service or provide them in another format.
Please let me know if there is anything else you would like me to collect or test.
Thank you again for taking the time to investigate this issue.
Reply 3 of 5, by Dege
Ok, thanks for the info.
Yes, it's undoubtedly a memory leak, it'd be nice to trace down what is leaking exactly.
1) Could you test it without dgVoodoo, with native DDraw or some other wrapper? If the leak does not come with it then dgVoodoo is the culprit.
2) Could you run the game both with the D3D11/12 backends? If both leaks then it's unlikely that the driver is leaking.
Reply 4 of 5, by Dege
Another idea has just come to my mind: a typical resource leak could be that the game continuously (in each frame) creates a (small) DD surface for some temporary rendering work and then releases it.
And if there is some reference counting problem in dgVoodoo then it does not get released so those many objects slowly eat up the memory (address space).
It might be possible to figure it out from the dgv log (with API calls).
Reply 5 of 5, by ulinta
Hi Dege,
I completed the native DirectDraw test (without dgVoodoo).
I simply removed dgVoodoo's DDraw.dll and ran the game with Windows' native DirectDraw.
The game was left running as a merchant for more than 24 hours.
Results:
- No crash.
- No freeze.
- Virtual Size stayed around 440–445 MB after the initial startup.
- Private Memory also remained stable (around 270–286 MB).
- I did not observe the continuous Virtual Size growth that occurred with dgVoodoo.
So far, I have the following results:
- dgVoodoo D3D11: Virtual Size continuously grows to about 1761 MB, then the game crashes.
- dgVoodoo D3D12: Virtual Size continuously grows to about 1866 MB, then the game freezes (cg.exe remains running).
- Native DirectDraw: More than 24 hours without any crash, freeze or noticeable memory leak.
This seems to indicate that the memory leak only occurs when using dgVoodoo.
Regarding your latest idea about a possible DD surface reference counting issue, I'd be happy to collect a dgVoodoo API log.
Could you please tell me which logging options you would like me to enable and whether there is any specific log level or configuration you prefer?
Thank you!
