First post, by Miphee
Hypothetical question: ASUS CUR-DLS vs EPOX KP6-BS
    132.86 KiB
    693.74 KiB
Reply 1 of 37, by weedeewee
Why not both ? 🤣
anyway, I'd prefer the Epox since it has AGP and ISA slots.
Do not ask Why !
Reply 3 of 37, by paradigital
For me, dual s370 but with AGP, I’ve got two of those, one running dual 1GHz PIIIs and one modded to take dual 1.13GHz Tualatins.
The main reason is cooling, one of these systems is watercooled, using off the shelf water blocks, which is nigh on impossible with Slot 1.
If I was going to bother with Dual Slot 1, I’d rather go Dual Slot 2 for the rarity and oddity factor.
I’m happy with my single Slot 1/Asus P3C-E/RAMBUS/Powerleap Tualatin system for my Slot 1 tinkerings!
Reply 4 of 37, by mR_Slug
The lack of AGP on the Asus, suggests the Epox is more useful, as there are a lot of people who use this stuff for gaming. Though the lack of 64-bit PCI/PCIX on the Epox does limit SCSI expansion in say a server. I like old server stuff but i would say i'm in a minority compared to those into gaming. Has the Epox got a BX or GX chipset?
Though obviously dual and gaming usefulness, is limited based on the OS choice.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 7 of 37, by dionb
ISA is hardly relevant with dual CPU builds: you want ISA for DOS, and DOS doesn't do SMP. SMP-aware OSs like WinNT, 2k, XP (and various Unixen and more exotic options) are all perfectly happy with PCI (sound) cards.
AGP is another matter though. The issue here isn't So370 vs Slot1, but a workstation board like the KP6-BS vs a server board like the CUR-DLS. There are perfectly good dual So370 workstation boards out there with AGP (Asus' CUV4X-D for example, or if you want to go seriously high-end the Tyan S2567)
Reply 8 of 37, by CwF
maxtherabbit wrote on 2021-06-05, 19:22:
64bit PCI is cool as heck
Especially when we find lots of PCI cards run at 66 just fine!
I ran a few dual P3T's for a decade. One had the ISA occupied with a sound card and the adjacent shared slot with a sata controller with no header, all slots filled, a P3TDLE I think - so there ya go, ISA functional and 66 MHz PCI. It was good.
I used to know what I was doing...
Reply 9 of 37, by pshipkov
The clock generator on the Asus board goes to 180mhz.
You can have extra fun pushing it around.
There are better options out there, if you are looking to spend on dual p3 hardware.
retro bits and bytes
Reply 11 of 37, by dionb
Miphee wrote on 2021-06-05, 20:42:
Are there decent PCI video cards available for gaming?
Hardly. The one that springs to mind is the Matrox Parhelia, but the 64b PCI version was even slower than the AGP one. That CUR-DLS simply isn't a gaming board.
Reply 14 of 37, by matze79
yep and there are PCI VGAs who also will run 66Mhz.
So missing AGP isn’t that bad.
Reply 15 of 37, by Miphee
Are there 64bit PCI VGA adapters?
Isn't the Radeon 7500 PCI much faster than the V5 5500 PCI?
The Radeon is also cheap and readily available.
Reply 16 of 37, by paradigital
Miphee wrote on 2021-06-06, 10:15:
My Matrox Parhelia is a PCI-X interface, should operate at PCI 66 just fine.
Reply 17 of 37, by Miphee
paradigital wrote on 2021-06-06, 10:26:
Looking good! Any PCI-X VGA alternatives?
Reply 18 of 37, by paradigital
I have honestly only ever seen the Parhelia (and some lower end Matrox stuff) as a consumer/prosumer level video cards on PCI-X.
You see stuff like the HP Visualize and the IBM equivalents all over the shop, but I seem to recall they don’t work in PCs due to having BIOSes (and lack of drivers I guess) designed for big iron RISC computing.
Reply 19 of 37, by weedeewee
PCI-X to PCIe x4 or PCI-X to AGP x? adapters.
I think user sdz has designed those.
Do not ask Why !
