the video card surely makes some difference here, and i recommend using driver 30.82 for socket7 rigs with win2k/xp.
I just tried it and my score went down to 312. This driver is probably optimised for the GeForce 2 series - not so much for the TNT2.
I think getting more than 1/3 the score of a Geforce 2 Ultra with a TNT2 M64 on a similar CPU is very respectable. The GF2 Ultra is easily 5-6 times as fast as a TNT2 M64.
That said... coupling a system like that with Windows XP is probably torture. Have you tried running the same benchmark in 98SE?
(Also, I know you just did this to see what would happen... I'm just curious if the OS makes any difference in the score. 😀 )
Yeah, that makes sense to me.
Funnily enough, it feels just right. I don't wait for the system and it doesn't wait for me.
(Also, I know you just did this to see what would happen... I'm just curious if the OS makes any difference in the score. :) )
While I don't have 98 installed on here, I did try the benchmark on Windows 2000, which runs significantly faster. With Detonator 7.97 - the driver I used in my first post - I got a score of 312. I noticed that the program only ran 17 tests instead of 21 the first time around.
I've had the time of my life
I've never felt this way before
Yes, I swear, it's so true
I'm holding onto used hardware
maybe you are right and i just remembered it wrong in so many years. which version were you using then? maybe you can try 8.05, the last one before 1x.xx series.
i hate 1x.xx series because they can't disable vsync, and 2x.xx are mostly the same thing as 30.82, just a bit less mature(30.82 being the last in the serie actually).
SAME SPECS BUT DIFFERENT SYSTEM (Win98SE) + FAST WRITES IS ON! (1GB GOODRAM)
default clocks:
385 / 540 :
430 / 590 (maximum for my card):
15678 points seems to be the current records for this GPU with a Tualatin CPU😉
Nice tuning!
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
I bought a N100 mini PC, UHD730 DEV_46D1 and tried 3dMark2001 for fun. With a fresh 21H2, latest driver 32.0.101.6460, 3dmark2001 startup hang patch, I got the following error.
swapBuffer:Present D3DERR_DRIVERINTERNALERROR
Basically you get about 5-10 seconds into the car chase bench then it errors out. Same with the dragon bench if the car is disabled. I had to go back to 32.0101.6078 to find a version that didn't crash. 6130,6299,6314,6319,6325,6332,6449,6458,6460 all had the same problem with 3dmark2001.
The N100 was comparable to a 7500T with CPUz bench, with the N100 using 12W and the 7500T using 17W under max load. 3dmark2001 performance was worse with the N100.
The attachment Win98_69164.jpg is no longer available
I also posted this in the 'bought this (modern) hardware' thread.
I snagged this lovely king of Maxwell GPUs - an EVGA Titan X. I absolutely didn’t need this matter-antimatter warp reaction powered beast, but it was cheap & I happened to be in the part of town where the seller was, so I decided to pick it up anyway.
The attachment IMG_0968.jpg is no longer available
Naturally, the first benchmark I ran was the downright punishing 3DMark... 2001. Funnily enough, it outscored my RX 7900 XTX by nearly 2000 points (the Radeon gets 103,670).
The attachment Screenshot 2025-05-11 220850.PNG is no longer available
Perhaps one day I'll properly bottleneck the crap out of this card by pairing it with Windows XP and Windows XP compatible hardware--it is the fastest Windows XP-compatible GPU one can get, after all. For now though, I think I'll just use it as a beautiful decorative piece for the office.
On Intel 12th gen disabling HT gave me another 3000 points, Any benefit on AMD?
I gained ~700 points by disabling SMT, for a score of 106,280.
I know! I made the terrible mistake of using an external image host during the early days of this thread. 😒
I do have most, if not all of the old images on my file server. If I ever get the time, I may re-up at least some of the more interesting ones.
It's good to see that someone else is installing Win98 on a powerful machine 😀
Yeah I've definitely been watching your progress.
Respected.
I will continue to follow the related events.
