My 3DMark01 Mega Thread
Reply 820 of 848, by GemCookie
noshutdown wrote on 2024-11-29, 02:04:
the video card surely makes some difference here, and i recommend using driver 30.82 for socket7 rigs with win2k/xp.
I just tried it and my score went down to 312. This driver is probably optimised for the GeForce 2 series - not so much for the TNT2.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 821 of 848, by Ozzuneoj
GemCookie wrote on 2024-11-29, 19:06:
I think getting more than 1/3 the score of a Geforce 2 Ultra with a TNT2 M64 on a similar CPU is very respectable. The GF2 Ultra is easily 5-6 times as fast as a TNT2 M64.
That said... coupling a system like that with Windows XP is probably torture. Have you tried running the same benchmark in 98SE?
(Also, I know you just did this to see what would happen... I'm just curious if the OS makes any difference in the score. 😀 )
Reply 822 of 848, by GemCookie
Ozzuneoj wrote on 2024-11-29, 19:34:
Yeah, that makes sense to me.
Funnily enough, it feels just right. I don't wait for the system and it doesn't wait for me.
(Also, I know you just did this to see what would happen... I'm just curious if the OS makes any difference in the score. :) )
While I don't have 98 installed on here, I did try the benchmark on Windows 2000, which runs significantly faster. With Detonator 7.97 - the driver I used in my first post - I got a score of 312. I noticed that the program only ran 17 tests instead of 21 the first time around.
Reply 823 of 848, by noshutdown
maybe you are right and i just remembered it wrong in so many years. which version were you using then? maybe you can try 8.05, the last one before 1x.xx series.
i hate 1x.xx series because they can't disable vsync, and 2x.xx are mostly the same thing as 30.82, just a bit less mature(30.82 being the last in the serie actually).
Reply 824 of 848, by VooDooMan
VooDooMan wrote on 2021-10-01, 06:41:
Here's an update on WinXP […]
CPU: PIII-S (sl6by) @ 1750MHz (166,6 MHz FSB, AGP @ 66.7 MHz!!!)
MoBo: ECSP6S5AT- SiS 635T chipset
RAM: 1GB DDR @ 310MHz (2,5-2-2-6 timings)
GPU: GeForce 6800GT @ (different clocks ) - 81.98 driver
System: Windows XP
Default clocks:
385 / 540 :
430 / 590 (maximum for my card):
UPDATE, UPDATE, UPDATE! 😉
CPU: PIII-S (SL6BY) @ 1900MHz (181 MHz FSB, AGP @ 72.4 MHz!!!)
RAM: 1GB DDR(GoodRam) @ 362MHz (2,5-2-3-6 timings)
GPU: GeForce 6800GT @ (different clocks ) - 81.98 driver - FAST WRITES off!
System: Windows XP
Default clocks:
385 / 540 :
SAME SPECS BUT DIFFERENT SYSTEM (Win98SE) + FAST WRITES IS ON! (1GB GOODRAM)
default clocks:
385 / 540 :
15678 points seems to be the current records for this GPU with a Tualatin CPU 😉
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 825 of 848, by DarthSun
VooDooMan wrote on 2025-01-16, 14:32:
UPDATE, UPDATE, UPDATE! ;) […]
System: Windows XP
Default clocks:
385 / 540 :
System: Windows XP
Default clocks:
385 / 540 :
default clocks:
385 / 540 :
Nice tuning!
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 826 of 848, by pappyN4
I bought a N100 mini PC, UHD730 DEV_46D1 and tried 3dMark2001 for fun. With a fresh 21H2, latest driver 32.0.101.6460, 3dmark2001 startup hang patch, I got the following error.
swapBuffer:Present D3DERR_DRIVERINTERNALERROR
Basically you get about 5-10 seconds into the car chase bench then it errors out. Same with the dragon bench if the car is disabled. I had to go back to 32.0101.6078 to find a version that didn't crash. 6130,6299,6314,6319,6325,6332,6449,6458,6460 all had the same problem with 3dmark2001.
The N100 was comparable to a 7500T with CPUz bench, with the N100 using 12W and the 7500T using 17W under max load. 3dmark2001 performance was worse with the N100.
N100 UHD730
3DMark Score	25170
Game 1 - Car Chase - Low Detail 477.0 fps
Game 1 - Car Chase - High Detail 58.7 fps
Game 2 - Dragothic - Low Detail 472.1 fps
Game 2 - Dragothic - High Detail 193.8 fps
Game 3 - Lobby - Low Detail 450.7 fps
Game 3 - Lobby - High Detail 102.6 fps
Game 4 - Nature 203.4 fps
Fill Rate (Single-Texturing) 2750.0 MTexels/s
Fill Rate (Multi-Texturing) 9666.4 MTexels/s
High Polygon Count (1 Light) 245.4 MTriangles/s
High Polygon Count (8 Lights) 116.6 MTriangles/s
Environment Bump Mapping 914.1 fps
DOT3 Bump Mapping 511.0 fps
Vertex Shader 508.1 fps
Pixel Shader 554.9 fps
Advanced Pixel Shader 500.4 fps
Point Sprites 140.3 MSprites/s
7500T UHD630
3DMark Score	33651
Game 1 - Car Chase - Low Detail 479.1 fps
Game 1 - Car Chase - High Detail 71.3 fps
Game 2 - Dragothic - Low Detail 685.5 fps
Game 2 - Dragothic - High Detail 275.6 fps
Game 3 - Lobby - Low Detail 479.7 fps
Game 3 - Lobby - High Detail 148.5 fps
Game 4 - Nature 365.0 fps
Fill Rate (Single-Texturing) 5880.6 MTexels/s
Fill Rate (Multi-Texturing) 11234.5 MTexels/s
High Polygon Count (1 Light) 454.8 MTriangles/s
High Polygon Count (8 Lights) 151.7 MTriangles/s
Environment Bump Mapping 1173.0 fps
DOT3 Bump Mapping 807.7 fps
Vertex Shader 534.6 fps
Pixel Shader 737.8 fps
Advanced Pixel Shader 768.5 fps
Point Sprites 183.5 MSprites/s
98/XP/XP64, ASUS A8V Deluxe, A64 3200 Venice [67W], 2GB DDR400, Ti4200 128MB [35W], M4 128GB SSD w/SATA-PATA
XP/XP64, GA-F2A68HM-HD2, A8-7600 [45W], 16GB DDR3-2133, Zotac GTX750 1GB passive [55W], 2TB SSD
Reply 827 of 848, by Kamerat
Many years since my last result, hardware is trash picked.
With this setup I got 17574 3D marks at default resolution:
  • ATI Radeon X300 Pro 128MB DDR @ 525MHz/309MHz
  • Intel Core 2 Duo E6600 @ 3400MHz 8x425MHz
  • Asus P5N-E SLI
  • 1024MB DC DDR2 @ 283MHz 4-3-3-1T
  • Windows XP Pro SP3
The attachment 3dm01-17574_gpu-525-309_cpu-3400_fsb-425_mem-dc-283-4-3-3-1t.PNG is no longer available
YouTube channel
Reply 828 of 848, by GokuSS4
all those screenshots lost 😒
Win10 Ryzen 7 5800X | TUF B450M-Pro | 32GB DDR4-3800 CL16 | RX 6800 XT
WinXP Core i3-3220 | H77 Pro4-M | 8GB DDR3-1600 CL9 | X1950 Pro
Win98SE Pentium E5800 | 775i65G R3.0 | 512MB DDR1-400 CL2 | X850 XT
Reply 829 of 848, by Archilion
3DM 2001
P4 2.8GHz, 1GB RDRAM and GF FX 5900XT - 11669 pts. ;(
Northwood P4 2.8GHz FSB400, GF FX 5900XT, 1GB RDRAM
C2Q9400, ATI X1950 XT, 2x240GB SSD, 4GB DDR2 800
Reply 830 of 848, by DarthSun
Win98 record :
The attachment Win98_69164.jpg is no longer available
Reply 832 of 848, by Standard Def Steve
I also posted this in the 'bought this (modern) hardware' thread.
I snagged this lovely king of Maxwell GPUs - an EVGA Titan X. I absolutely didn’t need this matter-antimatter warp reaction powered beast, but it was cheap & I happened to be in the part of town where the seller was, so I decided to pick it up anyway.
The attachment IMG_0968.jpg is no longer available
Naturally, the first benchmark I ran was the downright punishing 3DMark... 2001. Funnily enough, it outscored my RX 7900 XTX by nearly 2000 points (the Radeon gets 103,670).
The attachment Screenshot 2025-05-11 220850.PNG is no longer available
Perhaps one day I'll properly bottleneck the crap out of this card by pairing it with Windows XP and Windows XP compatible hardware--it is the fastest Windows XP-compatible GPU one can get, after all. For now though, I think I'll just use it as a beautiful decorative piece for the office.
"A little sign-in here, a touch of WiFi there..."
Reply 833 of 848, by Dothan Burger
Standard Def Steve wrote on 2025-05-13, 04:24:
I also posted this in the 'bought this (modern) hardware' thread. […]
On Intel 12th gen disabling HT gave me another 3000 points, Any benefit on AMD?
Reply 834 of 848, by Standard Def Steve
Dothan Burger wrote on 2025-05-13, 11:29:
I gained ~700 points by disabling SMT, for a score of 106,280.
GokuSS4 wrote on 2025-04-09, 19:45:
I know! I made the terrible mistake of using an external image host during the early days of this thread. 😒
I do have most, if not all of the old images on my file server. If I ever get the time, I may re-up at least some of the more interesting ones.
Reply 835 of 848, by Dothan Burger
ITX 98/XP gaming system. QM57 ITX / i7 640M / 2x 1GB / 7950GT PCIE / Audigy / 3COM Nic / Fractal Ridge
Reply 836 of 848, by DarthSun
Dothan Burger wrote on 2025-05-24, 03:26:
It's good to see that someone else is installing Win98 on a powerful machine 😀
Reply 837 of 848, by Dothan Burger
DarthSun wrote on 2025-05-24, 04:23:
Yeah I've definitely been watching your progress.
Reply 838 of 848, by DarthSun
Dothan Burger wrote on 2025-05-24, 21:16:
Respected.
I will continue to follow the related events.
Reply 839 of 848, by TM30
VIA Epia-ML at it's limits. 909 3DMarks2001:
VIA C3 667 Nehemiah 667 @ 1133 Mhz
512MB DDR RAM 133Mhz CL2-2-2-5 and 1T Command Rate
Via Unichrome, 64MB shared DDR RAM 133/133 @ 168/133
Win98SE
